Para não existir mais duvidas aqui vai os pneus que a NoTubes aconselha a serem convertidos mesmo não sendo tubless.
Stan’s NoTubes mountain bike rims require only yellow tape and universal tubeless valve when running tubeless. All tube-type mountain bike rims require a rubber rim strip to be converted for tubeless use.
Stan’s NoTubes mountain rims and converted tube-type mountain rims will work successfully tubeless with most types of tires including standard tube-type tires, tubeless ready tires, and tubeless specific tires.
Other brands of tubeless specific rims require tubeless specific tires or tubeless ready tires for successful tubeless use. These brands of tubeless specific rims can be converted for use with standard tube-type tires with the correct rubber rim strip.
Road tubeless applications require tubeless specific road tires. Tubeless specific road tires have a reinforced bead that will handle high pressure tubeless use.
Compatible Tubeless Tires:
Most Tubeless tires are compatible:
UST, LUST, UST-lite, 2Bliss, Tubeless Ready, TNT (tube no tube)
Compatible Non Tubeless* tires:
29er Tires: All
26inch Tires:
Nokian
Continental
Kenda
Specialized
Bontrager
Geax
Maxxis
and most other brands
Not Recommend Tires
WTB TCS and UST 29 inch tires are too tight for Stan's Notubes rims and NoTubes licensed rims such as Sun Ringle Black Flag.
Hutchinson Air-Light tires – the bead is too weak for tubeless use resulting in tire blowing off the rim at low inflation pressures.
Hutchinson Tubeless Cyclocross tires – carbon fiber tire bead requires excessive pressure to seat properly often leading to tire blowing off the rim.
*Use of sealant in non-tubeless tires may void the tires manufacturer’s warranty.
Tech Tip - Tire pressure
To determine a starting tire pressure when running NoTubes tires with our ZTR rim use this simple formula.
Rider Weight in pounds divided by 7 = x
x - 1 = Front tire pressure in PSI
x + 2 = Rear tire pressure in PSI
Bicicleta de montanha Stan NoTubes jantes exigem somente fita amarela e universal válvula tubeless ao executar tubeless. Todos mountain bike tipo tubo jantes requerem uma faixa borda de borracha para ser convertido para uso sem câmara.
Montanha de Stan NoTubes jantes e convertido montanha tipo tubo jantes funcionará com êxito sem câmara com a maioria dos tipos de pneus, incluindo padrão do tipo tubo de pneus, pneus sem câmara prontos e pneus sem câmara de ar específicas.
Outras marcas de jantes tubeless específico exigem pneus sem câmara específicas ou pneus tubeless pronto para uso sem câmara de sucesso. Essas marcas de jantes tubeless específico pode ser convertida para uso com o padrão do tipo tubo pneus com a faixa correta de borracha borda.
Aplicações rodoviárias sem câmara exigem pneus de estrada tubeless específicos. Pneus de estrada tubeless específicos têm um cordão reforçado que vai lidar com o uso de alta pressão sem câmara de ar.
Compatível Tubeless Pneus:
A maioria dos pneus sem câmara são compatíveis:
UST, luxúria, UST-lite, 2Bliss, Tubeless Ready, TNT (tubo sem tubo)
Compatíveis não Tubeless * pneus:
29er Pneus: Todos
Pneus 26inch:
Nokian
continental
Kenda
Specialized
Bontrager
Geax
Maxxis
ea maioria das outras marcas
Não recomendo Tires
WTB TCS e UST 29 polegadas pneus estão muito apertadas para Notubes Stan NoTubes jantes e jantes licenciadas como Sun Ringle Black Flag.
Hutchinson Air-Light pneus - a pérola é muito fraco para tubeless uso resultando em pneu soprando o aro a pressões de inflação.
Hutchinson Tubeless Cyclocross pneus - fibra de carbono talão do pneu requer uma pressão excessiva para assentar corretamente, muitas vezes levando a pneu soprando fora do aro.
* Uso de selante não-tubeless pneus podem anular a garantia do fabricante de pneus do.
Dica técnica - A pressão dos pneus
Para determinar a pressão dos pneus de partida ao executar pneus NoTubes com nosso aro ZTR usar esta fórmula simples.
Peso em libras Rider dividido por 7 = x
x - 1 = pressão do pneu dianteiro em PSI
x + 2 = pressão do pneu traseiro em PSI
