Boa noite para todos!
Desde de já fica todas as mudanças de firmware efectuadas no Colorado 300 da versão v2.50 para a v2.60 (parece que foram muitas!):
Change History
Changes made from version 2.50 to 2.60:
Added ability to turn elevation shading off, included in user profile settings
Added ability to log a comment with geocaching Field Notes
Added ability to save map selections to user profile settings
Added compass setting to saved user profile settings
Added tracback along current track
Added ability to determine public land survey or USGS Quad name for Topo 24k HD cartography
Added progress bar during software updates
Added error message when the max number of geocache or gpx files is exceeded
Added ability to search near a map point
Added ability to use the map to add a point to a route
Fixed shutdown when deleting a waypoint from the map
Improved odometer distance calculation
Improved Wherigo engine
Improved backlight behavior
Improved compass / GPS heading autoswitch behavior
Improved keyboard behavior in address & intersection searches
Improved behavior in low battery state
Improved behavior of turn-by-turn route recalculations
Improved map drawing to eliminate redraws when not necessary
Improved map drawing to reduce partial map draws
Improved map drawing to enhance appearance of trails
Improved usability of WGS84 by listing as a datum rather than just a spheroid
Improved automatic track archiving when archiving very lengthy activity segments
Improved button behavior when logging geocache attempt
Improved stopwatch timing
Improved distance precision when reviewing a point and tracks
Improved inter-tidal color in non-marine colors
Improved readability of geocache_visit.txt
Increased maximum number of GPX files processed to 200
Corrected guidance text to not truncate streets when not necessary
Corrected behavior of proximity alarms in custom points of interest
Corrected potential issues that prevented user alarm from sounding
Corrected map drawing above 75 degrees latitude
Corrected potential issue when attempting to delete profiles
Corrected issue that generated extra waypoints at poweron when 'Mark Waypoint' was the first listed shortcut
Corrected potential issue preventing 'Waypoints' from being listed in 'Where to?'
Corrected issue that prevented poor signal strength messages from disappearing if a fix was achieved
Corrected calculated issue that prevented complete display of large numbers
Corrected specified schema path for GPX files
Corrected Dutch keyboard to include 'Z' for address searches
Corrected User Grid to retain settings between power cycles
Corrected User Grid to allow 'E' and 'W' for longitude origin entry
Corrected shutdown issue when unit has empty Saved.gpx file
Corrected issue of missing active route when you select 'GO' from the full screen map in geocache mode
Corrected issue when selecting a custom poi from the recent found list after it is removed from the system
Corrected issue when selecting units on the stopwatch page using non-English languages
Corrected issue when you spell a geocache and the list doesn't reduce when the keyboard auto-pops
Corrected issue where you can't get to a hint for a geocache once you set it to found then back to unfound
Corrected issue where the chart information option would show up incorrectly
Corrected duplicate entries in the other menu when in page loop mode
Corrected external power lost message in non-English languages
Corrected issue with waypoint symbol selection shutdown
Corrected issue where the unit will hang when you try to restore a Wherigo cartridge
Corrected potential shutdown going to mass storage mode when you have custom POI's loaded
Corrected issues with Cyrillic characters
Peço a alguém mais entendido nestas lides, o favor de "traduzir em termos práticos" e mais resumidas, as alterações ocorridas.
Será que com este novo firmware foram corregidos os problemas que o pessoal tanto se queixava?
Será que neste novo firmware estão de volta os "detalhes" interessantes, existentes na série 60CSX?
Desde de já, o meu Obrigado! kimkiko
