Oregon 450
Ricast
Problema resolvido
http://garminoregon.wikispaces.com/Miscellaneous
"Recovery #1 -- Forced USB Mass Storage Mode (only available in release 2.85 and after)
If your Oregon freezes during the startup process (i.e. Loading Maps...), and you've just loaded new maps or new gpx files then it could be the new files which are causing the problem. This procedure forces the unit into USB Mass Storage mode so that you can delete (or rename) these files. Follow these steps to recover:
Attach the Oregon to your computer via USB cable
The Oregon will power on and start to boot, immediately power the unit off while still connected
Power on the Oregon and continue to hold down the power button for 30 seconds
The Oregon should enter USB mass storage mode
From your computer remove or rename any gpx, map files (.img or .kmz) files that were recently added
Unplug the Oregon and power on to see if this remedies the problem
During step 3) you should only see the Garmin banner for 30 seconds followed immediately by the graphic that shows a computer connected to a GPS. If you see any other text such as your custom banner, banners for loading maps, waypoints, etc then you have not held down the power button long enough."
nani
Viva,
Há cerca de 2/3 semanas atualizei o sw do meu oregon450 através do Garmin Connect.
O problema é que desde então aparece a seguinte mensagem "Can´t authenticate map" quando ligo o GPS.
Quando estou a utilizar o GPS aparece o track mas não aparece o mapa.
Será que me podem ajudar?
Obrigado,
shelltox
Essa nova versão de firmware deve ter novas rotinas contra mapas não autenticados. Soluções:
-usar mapas gratuitos (sem licenças de utilização).
-contactar vendedor,se já vinham instalados aquando da compra.
-Fazer downgrade para a versão sw anterior.
MaHogeny
A desenterrar topico...
Olá!
Adquiri um Garmin Oregon 450.
Já consegui colocar o mapa TopoLusitania.
Mas, como é que eu gravo os meus percursos?
Estava habituado a usar o strava no telemovel e era só carregar em gravar e fazer pausa ou stop.
No garmin, não vejo menus para isso.
Alguma dica?
No menu principal escolher trajectos depois aparece um sub menu com varias opções "gravar/não gravar/gravar e mostrar no mapa etc" (é isso se não estou em erro). É escolher o que interessar e começar a gravar. No final do percurso, no gestor de trajectos, fazer guardar percurso para o finalizar (atenção que o aparelho tem duas opções de guardar o percurso: uma para guardar só aquele percurso e outra para deixar em aberto a continuação da gravação de mais etapas). Aconselho a antes de se iniciar a gravação de um percurso, no computador de viagem repôr tudo a zeros. Se o aparelho for mantido sempre em gravação, mesmo desligado ele mantêm uma memoria. No caso de se iniciar o percurso num ponto diferente do local onde se desligou o aparelho, por exemplo: deslocamo-nos de carro da nossa residência até um ponto a dezenas de kms para iniciar a pedalada, quando ligamos o aparelho para iniciar a gravação do track, ele vai traçar uma linha recta entre esse ponto e o local onde foi desligado. Resultado: ao exportar o track aparece a tal linha recta ligada ao percurso que gravamos. O problema depois dá para resolver nos sites de edição de tracks, mas evita-se esse trabalho
Cps
MaHogeny
Boa tarde!
Obrigado contreiras.
Encontrei o menu que falas e ja consigo finalizar a gravaçao dos percursos onde quero.
Podia ser mais simples e intuitivo, em vez de andar com menus para a frente e para trás. Mas já faz o que queria.
Agora, não consigo ligar-me ao site garmin connect. Consigo detectar o Oregon com o Garmin Express, mas depois nao consigo com o site garmin connect. É preciso alguma configuraçao especial? Ou devia ser automatico?
Abraço a todos
Não uso o garmin connect (tambem tive problemas para o site reconhecer o aparelho) para exportar os tracks. Uso o gpsies e nunca tive problemas.
Cps
MaHogeny
Não consigo entender.
No site da garmin diz:
[h=3]"...Com uma ligação simples ao seu computador e à Internet, pode obter uma análise detalhada das suas actividades e enviar trajectos para o seu dispositivo exterior, utilizando o Garmin Connect™. " https://buy.garmin.com/pt-BR/BR/fitness-e-outdoor/discontinued-166/oregon-450/prod63349.html[/h]Por mail, dizem-me assim: "Obrigado por entrar em contato com Garmin Iberia. Informo que seu Oregon 450 não é compatível com Garmin Connect."
Depois, pergunto a alguns vendedores de garmin oregon 450 no olx, e eles dizem-me que conseguem carregar percursos no garmin connect.
Eu... nao consigo :(
gcaetano
MaHogeny,
Eu tenho um Dakota e não consigo carregar diretamente no Garmin Connect. Tenho de carregar manualmente. Já no caso do Edge é tudo automático...
O texto da garmin pode induzir em erro, mas o que me parece que eles querem dizer é que tu podes analisar os teus percursos carregando-os para o GC. A partir do Oregon tens de os carregar manualmente (procurar o ficheiro na pasta GPX). Compatibilidades diretas de dispositivos com o GC creio que só alguns relógios e a gama Edge.
MaHogeny
gcaetano
Certo. Já consegui carregar manualmente! E depois carrega directamente no Strava, por exemplo.
Pensei que fosse automatico, mas nao é!
Mas tambem não é o trabalho que dá em arrastar um ficheiro de uma janela para a outra.
Obrigado pela dica.
Para o btt está configurado.
Agora vou procurar configuraçoes para uso em geocaching!!
gcaetano
MaHogeny, se ainda não te entendeste com as configurações para um perfil de utilização de geocaching, diz. Posso dar-te algumas ideias caso seja necessário. ;)
Boas voltas!
