Glossário da suspensão - Em Inglês!
Aksium
Durante mais uma sessão de pesquisa, na tentativa de aumentar os meus conhecimento técnicos de forma auto-didacta encontrei este glossário sobre suspensões.
Peço desculpa por estar em Inglês, mas com o tamanho dele iria demorar algum tempo a fazer a tradução.
Para quem não tiver conhecimentos de Inglês suficientes pode sempre efectuar a tradução em: http://www.google.com/translate_t
Espero que o mesmo seja util.
FRONT SUSPENSION TERMINOLOGY
:arrow: Air Cap – Top cap that threads into top of air/spring leg (this is the left leg of the fork as you are
seated on the seat). Forks may be controlled with an air/spring or a coil spring. The air cap
contains the Schrader Valve, which is used to control the spring rate or SAG of air forks.
:arrow: Air Spring – A mechanism that is used to control the SAG of an air fork.
:arrow: Arch – A support that connects the two outer lower legs of the casting so as to keep them moving
in unison.
:arrow: Black Nitrate Leg Coating – New coating for steel stanchion legs that reduces stiction.
:arrow: Boss – The word used to describe an outer casting that has brake posts for V-brakes or
cantilever brakes.
:arrow: Bottom Out Bumper – A rubber or elastomer device that absorbs the shock that occurs when a
suspension is compression to its limit.
:arrow: Bushings – A cylindrical sleeve between a fork stanchion tube (inner leg) and a fork outer
casting (slider), which facilitates the sliding movement between these two parts.
:arrow: Cartridge Damping – Provides better oil flow, bump sensitivity, and improved damping control in
long travel applications.
:arrow: Click-It Remote – A handle-bar lever actuated system that controls the lock out function on front
and rear suspension products. It is activated by pressing the Red Lock button and unlocked by
pressing the Green Release Lever.
:arrow: Coil Spring – A coiled piece of metal that acts as a spring to help suspend a fork.
:arrow: Coil Spring Air Assist – A new feature for 2005 that utilizes a full length coil spring and allows
you to increase the spring rate of the fork by adding air as a booster to that coil spring.
:arrow: Compression – The phase of the suspension operation in which the wheel travels up, or travels
closer to the frame. The suspension forks reaction to a bump in the trail.
:arrow: Compression Damping – Restriction of the rate that the suspension compresses under load.
:arrow: Convertible Travel – A system used to alter the travel of a suspension fork. It requires moving a
travel clip on the compression rod to a different position. This operation is accomplished by
disassembling the fork and physically moving the travel clip on the compression rod.
:arrow: Crown Steerer Assembly – the stanchion legs (inner legs), the fork crown, and the steer tube
pressed together as one assembly. This assembly is then finished by adding all of the fork
internals and then outer casting (slider).
:arrow: Damping – A function that modifies the rate of suspension compression or rebound.
:arrow: Detent – An indentation that causes a rotating adjuster to stop at fixed increments.
:arrow: Drop Out – The end of an outer casting (slider) where the wheel attaches.
:arrow: Dust Boot – Usually a piece of rubber in the shape of a cylinder with baffles to allow it to
compress as the fork compresses through its travel. Its function is to help keep dirt and water
from getting into the inner legs of the fork.
:arrow: E2 Air System – Lightweight alternative to coil springs for steel legged forks eliminates the need
for spring changes for various rider weights.
:arrow: FFD – Fluid Flow Damping. A Manitou patented low cost oil damping system. The compression
damping is non-adjustable and the rebound damping may be non-adjustable or adjustable
damping.
:arrow: Fork Crown – The component that joins the stanchion tubes (inner legs) to the steer tube of the
fork.
:arrow: Hydraulic Fork Oil – Oil used in suspension designs to provide damping. It has special
characteristics that determine how it reacts when exposed to compressed air, how it changes
viscosity when its temperature changes, and how it moves through valves.
:arrow: Hydraulic Lock Out – a condition caused when the mixture of air and damping oil is out of
balance. It is caused when there is too little air space in a chamber, not allowing the fork to
compress through its travel.
:arrow: IS2 Integrated Stem System – integrates top triple clamp with bar mount, eliminating the need
for a stem. Flip Flop mount allows for 45mm or 60mm stem measurements and spacers allow bar
height adjustments. Includes shims for both 31.8 and 25.4mm handlebars.
:arrow: Infinite Travel System (IT) – A handle-bar mounted air travel adjust system that allows the rider
to change the fork travel (and ride height) without a spring rate change. The travel can be
changed from full compression to full rebound and at any place in between.
:arrow: Intrinsic Damping– speed sensitive SPV based damping system for long travel applications.
Provides better sensitivity to small bumps and superior bottoming resistance.
:arrow: Lock Out – a special function that restricts the compression of the fork from moving. It is
generally controlled by an external knob that is activated when a rider does not want the fork to
move, thus eliminating extra energy needed to overcome the bobbing forces of the fork.
:arrow: MCU – (Micro-Cellular Urethane) Special urethane that is filled with tiny air cells that act like
springs when the elastomer is compressed.
:arrow: No Boss - The word used to describe an outer casting that has no brake posts for V-brakes or
cantilever brakes. This casting is to be used for disk brakes only.
:arrow: No Tools SPV Volume Adjust – A new system designed to work with SPV as a control of the
compression ramp up rate of the fork. It has a 4-position range of adjustments from linear to very
progressive, adjustment doesn’t require a socket.
:arrow: No Tools Hex Lock Axle – Update of patented Hex Lock through axle provides simple and
effective wheel removal system without requiring tools. Features dual quick release to remove
pinch pressure and the axle is tighten and loosened with hand turned side tension bolt.
:arrow: Oil Damping – A system that uses the resistance to oil flow through holes in a valve to provide a
means to alter the rate of suspension compression or rebound.
:arrow: Oil Level – The level of damping oil needed for the optimal damping performance of a
suspension. It is measured as the air space distance between the top of the stanchion leg (inner
leg) and the height of the oil inside of the leg. The fork must be completely extended in order to
get an accurate measurement.
:arrow: O-Ring – A soft, flexible neoprene or Buna rubber ring with a round cross-section, which is used
for sealing and retention.
:arrow: Oil Weight – A description of the relative viscosity of oil, such as hydraulic oil. Oil with low weight
numbers (5wt or 7wt) flows through the valving with less resistance than higher weight numbers
(10or 15 wt).
:arrow: One Point Five Standard - 1.5 inch interface standard for frame head tubes, headset, cups,
stem, and steer tubes which allows for the lightest weight and strongest design in 170mm single
crown forks. This design greatly improves the control and steering precision of the fork. It is used
predominately on forks with longer travel and the intended use is for more hardcore, extreme
riding.
:arrow: Outer Casting – (see Slider)
:arrow: Preload – A condition of compressing a spring or elastomer before the operating loads are put on
the suspension, so that it provides a stiffer spring rate.
:arrow: Piston – In front suspension, the part of the damper that slides back and forth inside of the
damping leg that houses the valves. It can also refer to the air piston in the air/spring assembly
that slides back and forth compressing the air, thus causing a change in the spring rate of the
suspension.
:arrow: Porosity – The condition or property of having pores in a material that will allow gas or liquid to
pass through it.
:arrow: Platform Plus Damping – A new damping system found on 2005 Rear shocks (featured on
Metel and Radium’s). This system will establish a pedaling efficiency platform similar to SPV, but
is done through unique valving that is not adjustable (helps in bump control).
:arrow: Rapid Travel II, Wind Down – Systems that are used to control the travel of suspension forks.
Also known as RTII and WD. RTII is used for the specific purposes of controlling the travel in two
conditions: climbing and descending. WD is an incremental travel adjustment between two set
limits and does not affect the spring rate of the fork as severely as RTII.
:arrow: Quad Ring seal – New seal that replaces standard o-rings in designs that require more efficient
air and oil sealing methods.
:arrow: Rebound – The phase of the suspension operation in which the wheel returns to its original
position on the ground after compression.
:arrow: Rebound Damping – Restriction of the rate that the suspension rebounds when the compression
load is relived.
:arrow: Remote Lock out system – A handle-bar lever actuated system that controls the lock out
function on front and rear suspension products.
:arrow: Reverse Arch Technology – Also known as RA. It is a system that is designed to move the arch
of a fork to the backside of a fork, rather than the conventional front position. It was designed to
provide greater rotational torque strength to an outer casting (slider), without adding additional
weight to the fork.
:arrow: Snap Valve SPV– High platform, low threshold SPV damping system that is resistant to pedaling
induced movement but still offers bottoming resistance and small bump sensitivity.
:arrow: Sag – The amount a suspension fork compresses at rest with a normal load (rider’s weight).
:arrow: Schrader Valve – Valve used to introduce air into a chamber.
:arrow: Seal – A part, usually neoprene rubber or Buna, that keeps contaminants out and/or working
fluids in.
:arrow: Semi Bath – A lubrication system that uses a lubricating oil to keep the bushing surface and
stanchion legs (inner legs) as friction free as possible during movement of the stanchion legs.
:arrow: Spring Rate – The rate at which the resistance of a spring increases as it is compressed.
:arrow: SPV – (Stable Platform Valve) new damping system that allows the rider to set the pedaling
platform that he desires to pedal most efficiently in all situations. It is dependent on the pressure
that the SPV valve experiences from the movement of the wheel vs. the terrain and the platform
that is set by pressure introduced to other side of the SPV valve through changes of air pressure
working on the damping oil.
:arrow: SPV Evolve – The latest version of SPV damping technology that has increased its performance
with modifications to the original design.
:arrow: Slider/Outer Casting – The tube (outer casting leg) of the suspension fork that0. remains fixed to
the wheel. It slides up and down on the stanchion leg (inner leg).
:arrow: Stanchion Clamps - (Double-Triple Clamps) the portions of the fork crown that clamp around the
stanchion legs above and below the head tube of the bicycle frame on specific long travel
applications.
:arrow: Stanchion Legs – The suspension tube (inner leg) fixed to the fork crown. It remains stationary
during the operation of the suspension.
:arrow: Steer Tube – The long cylindrical tube that extends from the top of the fork crown. Its function is
to be inserted into the bicycle head tube and attach the suspension to the bicycle frame.
:arrow: Thru Axle – (Hex-lock) A device used for mounting a thru axle hub to special outer legs that are
not made for standard quick release hubs. Manitou’s Hex-lock (thru axle) system is a special
patented system utilizing a hex shaped end that increases the stiffness of the fork and reduces
slippage in the joint between the axle clamps and the axle.
:arrow: Top Out Bumper – A rubber, coil spring, or elastomer device that absorbs the shock that occurs
when the load is taken off a suspension so that it is allowed to rebound to its limits
:arrow: TPC – (Twin Piston Chamber) a patented damping system that has independent pistons for
rebound and compression. The system utilizes a mixture of air and oil in the damping leg of the
fork to enhance the damping performance.
:arrow: TPC+ - A variation of TPC that has added a floating piston to the compression damper to
enhance the performance of the compression damping under the load of bigger hits.
:arrow: Travel – The amount that a wheel moves between the most compressed and the most extended
states of the suspension
:arrow: Viscosity – A description of how a liquid flows. Liquids with higher viscosity are thicker flow less
easily or quickly than liquids with low viscosity. This has an affect on the damping speeds of
:arrow: Volume Control – A new system designed to work with SPV as a control of the compression
ramp up rate of the fork. It has a range of adjustments from linear to very progressive.
:arrow: Wiper Seal – A rubber material that is used as a seal to keep dirt and water out of the outer
casting legs. It is not designed to keep air pressure or extreme oil pressure in.
Jorgex
O meu drama é saber como se chamam as cosias em inglês porque até sei explicá-las em inglês mas o nome é que me falha sempre.
Dêem um pulo ao site da ParkTools porque lá há um pdf com centenas de nomes em inglês e depois a tradução ao lado em 5 ou 8 línguas diferentes.
B
Bttejo
poderias indicar o nome do pdf, por favor?
