PECIFICATION DESCRIPTION
SIZES S (15"), S/M (17.5"), M (19"), M/L (21")
COLOR(S) Satin Carbon w/ Red and Silver
MAIN FRAME C10 super-light high-modulus carbon w/ internal shift cable routing, shaped oversized ride-tuned down tube, tapered 1 1/8" - 1.5" head tube, PF30 bottom bracket
REAR TRIANGLE C10 super-light high-modulus carbon seatstays w/ shaped ride-tuned chainstay, carbon 142x12mm dropout and replaceable hanger
FORK Manitou Marvel LTD w/ remote lockout, tapered alloy steerer, 15mm Thru axle, 100mm travel
REAR SHOCK N/A
CRANKSET Shimano Deore, hollow Tech II w/ integrated spindle, 40/30/22T
BOTTOM BRACKET Shimano sealed cartridge, PF30 adaptor included
PEDALS N/A
FRONT DERAILLEUR Shimano Deore, direct-mount
REAR DERAILLEUR Shimano Deore XT shadow, 10-speed
SHIFTERS Shimano Deore, Rapid Fire, 20/30-speed
CASSETTE SunRace Driven, 11-36T, 10-speed
CHAIN KMC X10 w/ MissingLink, 10-speed
WHEELSET Vera Terra DPD22 rim 32h, Formula DC-51 front / DHT-142 rear disc hubs, stainless black spokes
TIRES Schwalbe Rocket Ron, 29" x 2.25" 67tpi, folding
BRAKE SET Shimano 355, hydraulic disc, 180/160mm rotor
BRAKE LEVERS Shimano 355, hydraulic disc
HEADSET FSA NO.42, 1 1/8" - 1.5", sealed bearing
HANDLEBAR Oval Concepts flat bar, 6061 alloy, 31.8mm, 9° sweep, 0mm rise, 710mm wide
STEM Oval Concepts 313, 6061 3D-forged alloy, 31.8mm, 7° rise
TAPE/GRIP Oval Concepts 600 SLO, dual-density Kraton, composite lock-on
SADDLE Oval Concepts 200 w/ steel rails
SEAT POST Oval Concepts 300, 6061 alloy, 31.6, double-bolt micro-adjust
WEIGHT, KG/LBS 12.22kg / 26.94lbs
