Ola boa noite, estou a pensar em iniciar o btt. ja fiz algumas pesquisas na net e agora passei para as lojas fisicas, do qual gostei destas duas bicicletas. mas se existir algum modelo por volta dos 800€ max que a malta conheça, poste ai para eu me poder decidir..
deixo agora as specs destes dois modelos..
Merida matts tfs 600
cannondale trail sl 4
Frame Trail SL, Optimized 6061 alloy, SAVE, 1.5" headtube
Fork SR Suntour XCR-LO, Coil, 100mm, Lockout, 1-1/8"
Crank Shimano FC-M391-8, Octalink, 44/32/22
Bottom Bracket Shimano BB-ES25, Octalink
Shifters Shimano Altus
Cog Set Sunrace M96, 11-34, 9-speed
Chain Shimano HG53
Front Derailleur Shimano Altus, 31.8 clamp
Rear Derailleur Shimano Alivio, 9-speed
Rims Maddux DC3.0 Double Wall w/eyelet, 28 hole front, 32 hole rear
Hubs Cannondale C4 front and rear
Tires Schwalbe Rapid Rob, 26x2.1
Pedals FPD Platform
Brake Cannondale Helix 6 Hydraulic Disc, 160/160mm
Handlebar Cannondale C3, 680x20, 6061 double-butted alloy
Stem Cannondale C4, 1-1/8", 31.8, 7 degree
Headset Tange Reducer 1.5 - 1-1/8"
Spokes Stainless Steel, 15g Black
Grips CANNONDALE DUAL-DENSITY GRIP
Saddle Cannondale Stage 3
Seat Post Cannondale C3, 27.2x350MM (S,M) 400mm (L,X)
desde ja muito obrigado a todos, e espero nao estar a desrespeitar em nada o forum, que esta muito bem estruturado..
abraço
Hugo Luz
Sizes | [14.5]-16-18-[19]-20-22-[24]" |
Frame | Matts TFS Pro-D-Single |
Color | silk black(anthracite/blue) |
Fork | RST First Air 100 Lockout |
Derailleur front | Shimano M590 |
Derailleur rear | Shimano Deore XT |
Shifters | Shimano SL-M591 -3 / -10 |
Brake levers | attached |
Brakes | Hayes Dyno Sport 180/160 mm |
Chainwheel | Shimano M522 octa 42-32-24 |
BB-Set | Shimano Octalink |
Chain | KMC X10 10s |
Hubs | Shimano M475 Disc |
Rims | Matts Comp ND |
Freewheel | Sram PG1030 11-36 |
Tires | Maxxis Aspen 2.1 fold |
Handlebar | Merida Pro OS, 640 / 25 mm Rise |
Stem | Merida Pro E OS, 7° |
Headset | FSA No.11p Neck |
Seatpost | Merida Pro H SB15, 31.6 mm |
Saddle | Merida Pro Stripe/Slim |
Pedals | XC Alloy |
Chain Shimano HG53
Pedals FPD Platform
abraço
Hugo Luz
