trick_shots
[h=2]Precisava da vossa opinião sobre esta suspensão.
O que me dizem dela?
Manitou Tower Expert Forks 29" 2012[/h]This example is an Original Equipment Tower Expert fork which has some minor differences from the aftermarket one, mainly the steer tube material. It is chromoly steel here, but aftermarket forks will all have aluminum steer tubes. Here are the tech bullet points on the Tower Expert
*ACT Air SpringFrom the Manitou website) Like MARS Air, ACT Air is a hybrid coil/air spring. However, while the coil and air springs in the MARS system work in series and contribute equally to the spring rate, the ACT Air system consists of a coil spring inside an air chamber. The energy of an impact is primarily absorbed by the coil spring. The air chamber provides enough adjustability to set the proper amount of sag for a given rider weight, and also contributes a certain amount of bottom-out resistance.
[h=3]Features:[/h]
[h=3]Features:[/h]
- Weight: 4.2lbs/1902.8 gms (Uncut aluminum steer tube. Our example weighed in at 4.7lbs with a steel steer tube, uncut)
- Travel: 80mm, 100mm, (internally convertible), and 120mm
- Spring: “ACT Air” *
- Spring Rate: Soft
- Bottom Out: Rubber Bumper
- Crown: Forged Hollow Crown
- Crown Finish: Black anodized (Our example has an optional to OEM’s painted black crown)
- Offset: 48mm
- Compression Damping: TPC Technology, “Absolute ”
- Rebound Damping: Adjustable TPC
- Adjustments Available: Air spring, Compression to Lockout, and Rebound.
- Legs: 32mm, 7050 Aluminum alloy straight wall.
- Brake MountM 6”
- Axle Type: 9mm QR
- Axle To Crown: 490, 510mm, 530mm (80mm, 100mm, and 120mm travel respectively)
