Gostave de ter umas opiniões sobre estas duas bicicletas:
GT ZASKAR CARBON 9R ELITE 2013 (c/ desconto 2000€)
Quadro : GT Zaskar 29er Carbon, Caixa direção 1/8"
Suspensão : RockShox Recon Gold RL 29, Solo air, 100mm, C/bloqueador
Aros : Alex XD-Lite, 32 raios F/T
Cubos : Frente- All Terra / Trás- All Terra
Raios : DT Swiss Competition
Pneus : Maxxis Aspen, 29x2.10 (F/R)
Pedais : GT
Pedaleiro: Sram S1000, 38/24T
Eixo Pedaleiro : Sram XR GXP
Corrente : KMC X10 - 10 Velocidades
Cassete : Shimano CS-HG62-10, 11-36t - 10 Velocidades
Mudança frente : Sram X5
Mudança trás : Shimano SLX - 10 Velocidades
Manípulos mudança : Shimano SLX 2x10
Guiador : Crankbrothers Cobalt 1 , 31.8mm, 680mm
Avanço : Easton EA50, 31.8mm
Caixa direcção : Fsa, 1.5"
Travões : Disco Formula RX (hidráulicos), 1680mm frente / 160mm trás
Manetes : Formula RX /li>
Selim : Fizik Tundra 2MG
Espigão de Selim : Crankbrothers cobalt 1
Punhos : GT
Garantia : Quadro (5 anos) Restantes componentes (2 anos) excepto peças de desgaste
Peso : 10.570 Kg
Specialized Stumpjumper Comp 29 (PVP 2000€)
QUADRO - M5 fully manipulated alloy, 29" geometry, tapered HT, PF30 BB, PM 140mm rear brake, 135mm dropouts, replaceable derailleur hanger
AMORTECEDOR TRASEIRO
FORQUETA - RockShox Reba RL 29, Solo air spring, alloy tapered crown/steerer, w/Lockout and rebound adj., QR, 15.5": 80mm, 17.5/19/21": 90mm travel
CAIXA DIRECÇÃO - 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
AVANÇO - Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, 6-degree rise, S: 75mm, M: 90mm, L: 100mm, XL: 110mm
GUIADOR - Specialized XC flat, 2014 butted alloy, 680mm wide, 8-degree backsweep, 31.8mm
PUNHOS - Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
TRAVÃO DIANTEIRO - Custom Magura MTS, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
TRAVÃO TRASEIRO - Custom Magura MTS, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
MANETES TRAVÃO - Custom Magura MTS, alloy master cylinder/lever blade, hollow lever pivot, reach adj.
DESVIADOR DIANTEIRO - SRAM X7, 10-speed, 34.9 clamp, top pull
DESVIADOR TRASEIRO - SRAM X9 Type 2, 10-speed, mid cage
MANÍPULOS MUDANÇAS - SRAM X7, 10-speed, w/MatchMaker clamp
CASSETE - SRAM PG-1030, 10-speed, 11-36
CORRENTE - KMC X10, nickel plate, reusable Missing Link
PEDALEIRA - Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 15.5": 170mm, Others: 175mm
CREMALHEIRA - 38/24
EIXO PEDALEIRO - SRAM PF30, OS press-in bearing, sealed cartridge
PEDAIS - Resin Test Ride Pedals with toe clips, CEN std.
AROS - Roval 29, alloy disc, 26mm wide, 32h
CUBO DIANTEIRO - Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
CUBO TRASEIRO - Specialized Hi Lo disc, double-sealed cartridge bearing, QR, 32h
RAIOS - DT Swiss Industry, stainless, 14g
PNEU DIANTEIRO - S-Works Fast Trak, 2Bliss Ready, 120 TPI, aramid bead, 29x2.0"
PNEU TRASEIRO - Specialized Fast Trak Control, 2Bliss Ready, 60 TPI, aramid bead, 29x2.0"
CÂMARAS DE AR - Ultralight presta
SELIM - Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
APERTO ESPIGÃO - Specialized 2014 butted alloy, single bolt setback, 27.2mm, 15.5/17.5" 350mm; Others: 400mm
ABRAÇADEIRA ESPIGÃO SELIM - Specialized 7050 hard anodized alloy, 31.8mm, single bolt
NOTAS - Protective clear coat, derailleur hanger, owners manual
Ja agora, agradeço opiniões de outras marcas/modelos até aos 2000€
A minha ideia é comprar numa loja fisica, senão nao pensava duas vezes na Radon
Pedais : GT
Punhos : GT
Peso : 10.570 Kg
CREMALHEIRA - 38/24
