Garmin EDGE 800
Klab
Eu também estou maravilhado com o connect, uso o 800 em tudo, indoor, caminhadas, etc coloquei de lado por completo o material que tenho da Polar :)
Nova versão de firmware disponível para update :)
Vers. 2.10
subeskema
Changes made from version 2.00 to 2.10:
* Improved Auto Pause behavior.
* Corrected issues that could cause incorrect speeds to be recorded.
* Improved auto wheel calibration especially for PowerTap power meters.
* Added a torque reading to the calibration page for Powertap power meters.
* Removed DeleteFiles folder.
* Allow the device to operate in normal mode with external power.
* Corrected issues that could corrupt activity files which would not allow them to be uploaded to Garmin Connect or Garmin Training Center.
* Improved keyboard layout, input, and design.
* Made improvements to the elevation profile.
* Added an activity reset reminder.
* Improved how the device responds when the screen has been locked.
* Added a factory default reset in MENU -> Settings -> System -> Initial Setup.
* Added the ability to view details for an activity that has not been reset.
* Data fields should now report correct time and distance while navigating.
* Corrected issues caused by removing an SD card while navigating.
* Corrected Auto Scroll issues.
* Corrected issues drawing the current activity on raster maps.
* Made improvements to the Virtual Partner.
* Added memory full warning message.
* Corrected issue that could prevent activities from being able to be deleted.
* Route recalculation can now be turned off in MENU -> Settings -> System -> Routing -> Recalculate.
* Added a day/night color mode setting in MENU -> Settings -> System -> Display -> Color Mode.
* Sensor settings will now be correctly maintained when merging FIT setting and sport files.
* Corrected issues with weight scale data recording and communication.
* Corrected issue that could cause lap calories to be reset after a power cycle.
* Corrected issue that could cause workouts, courses, and locations to not be displayed in their respective lists.
* Corrected issue that could cause data field changes on the map or elevation training pages to not be saved.
* Lap markers in a course will now be recorded correctly while following the course.
Com o upgrade possivelmente muitos dos problemas já abordados ficam resolvidos adicionando algumas funções também.
JNR
Regra geral o novo firmware está disponivel no site da marca e depois é só ligar o dito ao PC (ou Mac...) e deverá haver uma opção de acualização.
Nacs
Bom Dia,
Polegar, vais ao garmin.pt e procuras o separador SUPORTE, abres e seleccionas o 1º ícone: Webupdater.
Escolhe a versão que pretendes do Webupdater (caso corras o programa em windows, é a 1ª opção).
Instalas o programa, ligas o Garmin via cabo usb, o programa detecta a versão que tens instalada e instala automaticamente a nova versão do firmware.
Espero ter ajudado.
Cumprimentos e boas pedaladas
subeskema
Upgrade do firmware testado hj e em relação ao soluções do auto pause quando se está em andamento ficou a funcionar 5**** nem um soluço a passar por baixo de árvores....
lpsferreira
Também podes tirar o auto-pause, mesmo que pares tu o 800, ao reiniciares a marcha ele pergunta-te se queres recolocar em funcionamento. De qualquer modo eu já no 705 assim fazia, que é te-lo sempre sem auto pausa, no Garmin Connect dá para ver o tempo parado....
Nacs
Boa Noite!
Hoje finalmente tive oportunidade de testar a última actualização do firmware. De facto a Garmin empenhou-se e corrigiu muitos dos bugs da primeira versão. A Garmin afinou a máquina :)
Após meia dúzia de voltas em mato na Serra D'Ossa, posso afirmar que perdi todos os receios iniciais.
O Touchscreen é muito funcional, com lama, salpicos e umas luvas super grossas funciona 5 estrelas.
Relativamente às borrachas de protecção da entrada usb e do cartão de memória, acho-as seguras e até melhores que no Edge 705.
A configuração do Autopause está um espectáculo...até está afinada de mais! A bike movimenta-se um 1cm e lá começa ele a contar. Com tanto pause/start durante a volta até pensei que nos gráficos finais houvesse muitas falhas, mas não...nenhuma interferência nos gráficos do Garmin Connect.
Em suma, estou muito contente com o Gps!
Cumprimentos e boas pedaladas! :p
sepviri
recebi finalmente o meu Edge 800 a semana passada mas infelizmente ainda não tive oportunidade de o testar na bike.
É o meu primeiro GPS para bike e como tal gostaria de saber se me podem ajudar em como fazer upload de tracks para o Edge.
Nem sequer sei qual o formato que devo escolher nos sites de tracks... penso ser GPX mas não tenho a certeza...
E depois de os sacar para o PC, é só ligar o Edge ao PC e copiar os GPX para alguma directoria?
Sei que deve ser uma pergunta básica esta mas nunca tive um GPS...
Abraço,
/Vitor
Nacs
Boa tarde,
Sepviri, eu ainda não carreguei nenhum track gps no Garmin 800, mas penso que o processo é semelhante ao Edge 705 que tive anteriormente.
Relativamente ao formato dos track em gpx, este formato quando carregado para o Edge fica muito pesado e o aparelho tentava sempre fazer o auto-routing, mas penso que existia uma opção para desligar esta função (Isto acontecia do Edge 705).
Assim, aconselho a transformares o track gpx em tcx.
Para fazeres isto podes usar este programa: Tcx Converter. Abres o ficheiro gpx e convertes em tcx. Depois é só copiares e colares numa pasta do gps, que agora não te consigo dizer porque não tenho o aparelho comigo.
Após copiares o track para a pasta do gps, ligas o aparelho e vais a: Menu > Percurso > Seleccionas o percurso, aqui poderás ver algumas informações do track (distância, acumulado...).
Como disse, era assim que fazia no Edge 705 e penso que no Edge 800 não será muito diferente.
Só amanhã é que terei o gps na minha posse, assim só amanhã é que poderei precisar estas informações.
Abraço e boas pedaladas. :p
sepviri
Boas Nacs,
afinal o próprio GPS tinha um folder de documentação onde tinha o manual e carregar tracks é tão simples como arrastar o GPX para "/Garmin/New Files". e depois é só ir a menu->percursos e lá está o track... simples e sem problemas.
Abraços,
/Vitor
avlis66
Apenas uma chamada de atenção!!
No final das vossas voltas quando pararem o cronómetro e fazerem o reset para guardar o ficheiro da volta, NUNCA largar o botão antes da contagem decrescente finalizar.
Em consequência o ficheiro *.fit que o edge 800 produz poderá ficar danificado e assim perdem a vossa volta.
Caso o façam não conseguirão efectuar o upload para o Garmin Connect, conseguirão abrir o ficheiro no vosso edge mas este apresentará valores errados (ex.: 20000 m acumulado subida, 70000 Calorias, etc)
No fim da vossa volta, desliguem o bicho sem carregar no reset e façam o download no Garmin connect, assim não têm esse problema, o único senão é fazerem dois treinos sem terem a possibilidade de efectuar o download, e aí sim têm que resetar.
Em relação à capa p/ o ecran, comprei na fnac por 9,99€ a do iphone e serve perfeitamente. Não notei alteração na sensibilidade, reduziu foi a visibilidade, o que se resolve com a retroiluminação (não se preocupem com a bateria, dois treinos e quase 8h com a retro ligada a dois paus e ainda fiquei com 60% da carga da bateria). Calorias, mesmo problema que quase todos, treinos puxados e gastos calóricos ridículos, o reset do sistema resolve mesmo? Onde é que fazem a actualização do firmware, na pag. da garmin com não vi nada!
lucio2
Viva !
Só hoje tive oportunidade de voltar a dar uma voltita com o garmin e, actualizado o firmware, continuo com o já irritante auto pause sempre a ligar-se... onde posso desligar "isto" de uma vez por todas ?
Fiskit
Tenho um EDGE 800 e nas voltas que tenho dado, tenho constatado que ele dá-me valores de altimetria errados. Por exemplo, hoje mesmo, no trilho de algés para a cruz quebrada dava-me uma altimetria de -33, quando na realidade não é. Isto já aconteceu com algum de vós?, se sim, como conseguiram resolver. Fiz recentemente o update do firmware e ficou na mesma.
obrigado.
rsequeira
no meu nao contece isso ainda hoje fui dar uma volta e a altimetria esteve sempre correcta......tenta ir para um sitio onde conheças a altitude e inseria à mao....a partir dai fica como ponto de referencia. espero ter ajudado abraço
Scubalu
Estive a ver um edge 800 e achei o encaixe que é tipo ciclometro muito fraco para a prática de Btt o que é que acham ???
