Doping no Campeonato Nacional de Maratonas 2007
Torugo
Paulo.Cabanas said:
Eu explico. É demasiado dinheiro para as organizações pagarem.
Logo os atletas têm que se chegar à frente.
Como o CNAD tem a agenda ocupada mais dificil se torna.
É como nos impostos, és rico não pagas e depois de 5 anos és absolvido porque so desviaste. Se és pobre, apanham-te logo e roubaste o estado. Levas pela conta certa.
Assim quem toma anda 2 ou 3 anos na frente mas depois o pistão agarra e a camisa do cilindro fica toda arranhada. Com muitos prémios, mas toda lixada. Não podem é sair do pais.
Eu concordo contigo Paulo.
Os " :ideia: :ideia: :ideia: " eram irónicos. :D :D
Noctal
O procedimento do WADA para análise de testosterona
"Status in Sport
Testosterone is an anabolic agent and therefore prohibited both in and out of competition under the World Anti-Doping Code 2006 Prohibited List (effective from 01/01/06).
This list specifies that the presence of a testosterone (T) to epitestosterone (E) ratio of greater than four (4) to one (1) in the urine of a competitor constitutes an offence unless there is evidence that this ratio is due to a physiological or pathological condition.
In the case of a T/E result of greater than 4:1 and no other reliable analytical method applied it is mandatory that the relevant medical authority conducts an investigation before the sample is declared positive.
A full report will be written and can include a review of previous tests, subsequent tests and any results of endocrine investigations. In the event that previous test results are not available, the athlete should be tested unannounced at least once per month for three months.
The results of these investigations will be incorporated into the report. Failure to cooperate in the investigations will result in the sample being declared positive.
If another reliable analytical method is used to analyse the T/E ratio greater than four (4) to one (1) and this shows that the substance is of exogenous origin, no further investigation is necessary and the sample will deemed to contain such prohibited substance. "
paulo marinheiro
Utilizador Banido
Hoje ví o que muitos viram... (muitos mesmo, que quase toda a gente que conheço me diz que viu o puto na RTP2, quando dá)... a revolta contra o doping na primeira pessoa: o que perde contra o prevaricador, que neste caso é o António Silva, que na entrevista na RTP2 na prova de Castro-Marim dá um profundo grito de revolta, dizendo claramente "...fui roubado...", e que ganhou de raiva para ter o micro e poder expandir a sua revolta. Ele diz coisas muito acertadas, como por exemplo, que os veteranos deveriam ser exemplo para os mais novos, pois já nada ganham com isto, e que no caso dos veteranos, quem tomasse deveria ir e cito "... passear para o Inatel..." e ser banido de vez. E no caso do exemplo para os mais novos, o Fernando esteve bem... serviu de exemplo para os mais novos, que sabem agora bem, que se kitarem e forem apanhados, a glória e respeito são substituidos por, vexame, vergonha e descrédito em tudo o que fizeram e venham a fazer. Penso que é um bom exemplo, e que servirá para muitos que se pudessem tentar...! Feito desta nova forma às claras, e sem segredinhos, pois se fosse ás escondidas como costumava ser, a conversa era outra... e a moral também!
Desde a 1ª prova do Ricardo que o atleta António Silva tem sido um exemplo e uma bitola a seguir, e uma ajuda, pois um dia ele disse ao Ricardo na Trofa, onde o Ricardo nada tinha ganho ainda, e fez 3º "...quando meteres uma suspensão que bloquei-e, vais ganhar provas da taça..."... 4 dias depois estava uma Sid World Cup montada, e 3 semanas depois fez a 1ª vitória em Aviz e não se esqueceu que o Silva foi o unico, fora a gente os dois a acreditar que ele podia ganhar logo no 1º ano, e até nós desconfiávamos. É um grande exemplo de um grande atleta, num jovem grande atleta também... e tem oportunidade agora e novamente de ser bom exemplo bom conselheiro e bitola para os mais novos, no jovem atleta junior da própria equipa...
Este assunto numca está esquecido... agora começam a ser cometidos os erros, por aqueles que não conseguem chegar lá por meios legais de sofrimento e dedicação, ficando consecutivamente atrás... começando nesta altura os maus pensamentos... TRABALHEM MUITO E SE NÃO CONSEGUIREM...ACEITEM !!! Ou então façam uma associação de defensores de utilizadores de meios ilegais para ganhar provas, ou... corram uns contra os outros e dopem-se até à morte!
Espero que depois de todos os alertas e guerras que aqui e noutros sitios fiz, e depois desta entrevista do Silva, as pessoas em geral e a Federação em particular, se dediquem agora a defender e acarinhar QUEM TRABALHA E GANHA HONESTAMENTE e sofre por não optar pelo caminho sujo e perigoso.
Cumprimentos e muito respeito ao António Silva, e principalmente se ele vê o Forum, ou sabe da sua existencia por amigos ou outros... Toda a gente sabe que o Silva é o Campeão Nacional de XCO de 2007... apenas por um pormenor dos regulamentos, não pode ter o que é dele: a Camisola!
Espero que 2008 seja mais limpo... e vou estar atento a surpresas de caracois que só andam no nacional... espero que a Federação e o Cnad também estejam... pois em caso de atletas que numca ganharam nada... andam há 3 anos sem nada ganhar nem andar nada em lado nenhum, seja estrada ou XCO, e aparecerem do nada no dia do nacional e se ganharem ao meu atleta, estando este bem... será a ultima corrida do Ricardo em Portugal... deixando de correr em pistas viciadas e protegidas! Se andarem perto, todo ou quase todo o ano, e até ganharem algumas, serão respeitados por mim, e até uma vitória no Campeonato será aceite na boa, que a camisola não tem dono e aqui sabe-se perder e respeitar e honrar o adversário vitorioso... mas até agora... nada! tal como em 2006!!!!
paulo marinheiro
PS - Mr Orbea: quando souberes o que dizer e com verdade, fala, e eu apoio-te nesta luta contra o doping. Quando não souberes, não manches o nome, sem antes averiguares bem, de grandes e sacrificados atletas, no caso a Sandra Araújo, que tu meteste neste barulho de dopados, que acusou positivo sim senhora, mas cannabis... e experimenta fumar uma ganza e ir correr XCO a seguir e vê se isso te dá mais power ou te dá a camisola. A rapariga acusou uma substancia proibida mas que não está nas que fazem andar mais... está fora da ganancia... está no foro pessoal e só a ela, ao marido ou ao pai ela deve satisfações. Esta lei está errada... pois a tí nimguém te proíbe de beber Vodka, absinto, cerveja ou meter 30 xots numa noite se te apetecer... e estes não te fazem andar mais, mas o Charro está proíbido na lei desportiva, ainda que por questões de ordem social (um atleta deve ser exemplo, dizem eles), e também não te faz andar mais... Respeito pela Srª Sandra Araújo, a melhor atleta de XCO portuguesa de sempre e quanto a mim, o melhor de todos os tempos seja homem ou mulher e se tivesse as famosas condições certas podia ser uma das melhores do mundo... e se assim não fosse, o Ricardo não estaria na equipa que está, pois garanto-te e escreve... numca o Ricardo estará em equipas que compactuem e eaceitem dopados ou ex-dopados apenas para ganharem mais fácilmente, nem que corra individual. Só falo nesta questão aqui e imiscuindo.me em assunto delicado e que não é meu, porque o nosso presidente já o disse em publico para quem quis ouvir em Aviz em 2006!
E quem numca fumou um charro que atire a 1ª pedra...!!! Ou apanhou uma bebedeira... para ser mais soft...
MrOrbea
Paulo, apenas falei do que muita gente sabia, com o que foi apanhada ou não não sabia.
Mas acho que deve também servir de exemplo para os mais novos.
Sendo assim peço as minhas desculpas á Sandra e aos demais afectados pelo que aqui escrevi, mas como em Portugal não se sabe nada de concreto....(ou seja nunca sabemos com o que são apanhados os atletas.)
Torugo
EU não posso (e mesmo se pudesse, não iria, porque estamos a entrar na vida pessoal de cada um) atirar pedras...
paulo marinheiro
Utilizador Banido
Ok... entendido... não partam mais vidros... mas essa temática das drogas sociais nem sequer está aqui em discussão, porque não "rouba" provas, titulos ou lugares a nimguém, é uma opção pessoal que a cada um diz respeito, desde que não prejudique ou afecte a vida de nimguém, mas... nem uns copitos???!!! Uns xots???!!!... não atirem pedras, candidatem-se arcebispos e talvez cheguem a santos ou pápas... sem ofensa à liberdade de escolhas individuais, que não prejudiquem nimguém...claro, de quem numca bebeu alcool sequer...!
paulo marinheiro
Torugo
paulo marinheiro
Concordo plenamente!
Posso falar por experiência própria, quando andava na "boa vida", no outro dia tinha vontade era de ficar em casa sem me mexer.
Não estou a ver cannabis ou alcool (sim, porque apesar de legalizado, o alcool é uma droga), ajudarem a ganhar nada!!!
Talvez uma boa dor de cabeça, língua a saber a cortiça, umas más-disposições... Agora em termos desportivos....
betozeca
Olha,olha......AFINAL!!!
Tanta coisa e afinal a maior parte até gosta de umas ganzas...ah e tal é só um porro para rir um pouco,isto até é só uma groga social!!!!
nao ajuda em nada em termos desportivos e tal aquilo só faz rir mais nada,até vai ser uma prova divertida....é só rir!!!!!
SEM COMENTARIOS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
paulo marinheiro
Utilizador Banido
Olha olha... afinal!!!!... o quê????????????? O que Betozeca persegue? pessoal que faz da vida o que bem quer sem prejudicar ninguém mas que ao fazer o que a sua liberdade permite, incomoda-o e afecta-o? e quem achou? e o que achou? Betozeca pensa que alguém aqui disse que fuma ou fumou ganzas? betozeca terá percebido mal isso, e também a diferença entre entender a liberdade de escolha de quem faz o que a sí lhe dá prazer, mas a ninguém rouba nada... e quem toma tretas para enganar os outros, sejam os adversários ou os parvos que idolateram e acham fantástico os seus "quimicos andamentos"!
betozeca... respeitosamente: não confunda as coisas, este tópico é sobre DROGAS no desporto btt-xco, que aumentam artificialmente a performance com vista a superar outros que são melhores, porque se esforçam e sacrificam mais... outros foruns devem haver para debater as drogas socias, o alcoolismo, a dependencia de anti-depressivos, o vicio do jogo, entre tantos outros problemas da sociedade... que não estão aqui em discussão! aqui só se debate doping no desporto para enganar!
paulo marinheiro
nunohope
Amigos do btt, este é o primeiro tópico que entro, mas ainda bem que o tema é este. Desporto de alta competição não é nem nunca foi compativel com saude. Servindo isto como base, a utilização de métodos ilicitos para atingir altos resultados desportivos infelizmente é tao usual que poucos são akeles que não os utilizam. Se não utilizam na competição, utilizaram no treino. Se não utilizaram nenhuma "ajuda externa", fika para o ano, pois com toda a certeza não ganharam nada.
O Doping e o desporto, o Doping e resultados desportivos, infelizmente rimam tão bem que nunca deixará de existir essa simbiose.
Se o crime compensa na sociedade em e que vivemos, muito mais acontece no desporto...............terra dos dirigentes e medicos espertos e de atletas ingenuos sedentos de exitos a qualquer custo.
Posso estar a ser injusto para com aqueles que não tomam nada, mas esses, não sao vencedores, são sim desportistas na verdadeira assenção da palavra.
Boas pedaladas, mas pedaladas limpas.
paulo marinheiro
Utilizador Banido
...nada mais errado e de pior exemplo para putos novos... eu digo e em consciencia exactamente o contrário e poderia citar exemplos (muitos) de ganhadores, seja neste país ou noutros mesmo: é perfeitamente possível e existem ganhadores que não se dopam - nasceram com muito boa genética, e ou aplicam-se muito e levam uma vida correcta e regrada. O espirito colocado e exposto tão cruamente neste ultimo post, tem levado a uma consciencia do facilitismo no sentido de não se procurar levar uma vida de desportista de elite, com tudo o que de sacrificio esta obriga, e a um sentimento de não estar a fazer "tanto mal" ao enveredar por esse caminho que esta mentalidade propõe e dá como suposto unico caminho para a vitória, e só tem levado este país desportivo a ter apenas futebolistas, e 2 ou 3 destaques noutras modalidades, ficando a anos luz da vizinha espanha que tem campeões em todas as modalidades, em que só atletas de XCO levará 4 às olimpiadas, e no total de ciclistas são dezenas largas os que vão a Pequim, distribuidos entre pista, estrada, bmx, btt, só para citar o ciclismo, e nós dependemos de "estrangeiros naturalizados" para levarmos uma medalhita...
Discordo e posto a minha total discordancia e alerto aos mais jovens principalmente: apliquem-se se querem ser bons. se querem ser nº1, optem pelo desporto, sacrificando outras areas sociais da vida (copos, noitadas, nets até ás 2 da matina, Mcdonalds, falhas a treinos por dá cá aquela palha, etc...), levando uma vida que se compadue com a de um verdadeiro campeão. e acima de tudo acreditem que não é preciso tomar tretas para ser o the best. E tomem como exemplo a entrevista do Dr. Luis Horta, um suprasumo do desporto e actual director do CNAD (comissão nacional anti-dopagem) em que ele diz taxativamente e colocando o seu prestigio em jogo que a Rosa Mota e o Carlos Lopes NUMCA tocaram em doping na vida, e como quem me preocupa são os jovens, para os que não sabem, estes 2 atletas foram campeões olimpicos, na prova rainha das olimpiadas, a maratona, e o Carlos Lopes ainda detem, 24 anos depois o record olimpico, mesmo com tanta evolução em termos de tecnologia e compreensão da fisiologia e até da dopagem (nessa altura nem havia epo!!!).
Há, garanto, um atleta que ganha agora, irá ganhar muito mais e em outros sitios do mundo na sua vida, e que numca tocará em nada... e será exemplo! Mais o sigam... não podem é querer ter tudo o que a vida dá de bom, têem que fazer escolhas, por eles mesmos!
Penso que até é desacreditador de todo o desporto ser tão simplista ao ponto de colocar o vencedor inequivocamente ao lado do doping.
No que me toca, nada mais errado e leviano... eu tenho em casa um vencedor nato, que vence em portugal, em espanha e vencerá noutros locais porque trabalha muito e tem muitas vezes ele próprio que fazer escolhas dificeis para ter o nível que tem, e sinto-me ofendido com visão tão simplista... de quem numca deve ter ganho e procura justificações fora de sí...
Para ganhar não é preciso doping e dou 1 exemplo apenas: o homem que se fala e que foi apanhado, corria com os cadetes o ano passado, e o cadete mais rápido, ganhou quase todas as corridas C1 da taça à geral, em que corre com os veteranos, e foi com 15 anos, sempre... mais rápido em pista que o tal veterano... e por vezes partiu de trás e foi para a frente, sendo que em Porto-Mós era estrada direita sem nada técnico e ganhou na mesma.
Para quem acreditar nesta erradíssima visão digo: deixem-se levar, e vejam o exemplo deste grande atleta veterano que era até este ano,um Sr. repeitado na vida e nas pistas, e agora debate-se com toda esta gente a dissecar a sua vida, e vivam uma glória que pode ser vã e acabar em descrédito...
Este é um dos posts em que sou obrigado a ser anti-democrático e dizer abertamente que não respeito esta opinião... nem numca respeitarei!
paulo marinheiro
prasquete
As opiniões dos outros ate podem nem estar de consonancia com as nossas, até podemos nao as aceitar, mas temos de as respeitar... por este ou por aquele motivo, fulano tem uma opiniao diferente da nossa... a vida é assim... com respeito pelos outros haverá sempre maneira saudavel de se dizer o que se pensa...
Acho muito bem que o paulo diga o que pensa, eu tambem sou da opiniao dele... mas respeito opinioes contrarias... desde que com o minimo de fundamento, nao é so dizer por dizer...
cups...
sarah
Estou totalmente de acordo!! :wink:
Há depois os desportistas que se tornam vencedores (ou como disso o Paulo Marinheiro,há os que nascem já vencedores)...mas isso já é outra história...
Mesmo não lutando por ser numº1 no desporto, abdico de muito pois todos os dias (excepto fim de semana), acordo as 5h50 para ir nadar antes das aulas e ainda treino á tarde despois das aulas....e isso porque gosto de fazer desporto....não para ser campeã de coisa alguma....
Sarah Moniz
nunohope
Começo este post, com uma frase do sr Paulo “de quem nunca deve ter ganho e procura justificações fora de sí...”…..em prol do civismo e fair play prefiro não comentar tão infeliz comentário.
Amigos ou não perceberam onde quis chegar ou não soube explicar muito bem o meu ponto de vista. Aqui vai então.
Não tenho dúvidas acerca da existência de grandes desportistas, excelentes atletas geneticamente super favorecidos, miúdos que se sacrificam imenso pela procura de resultados positivos. Que a pratica desportiva saudável é o melhor caminho para estes jovens, ainda mais na sociedade perigosa e cheia de vícios que estamos a presenciar. Disso estamos todos de acordo.
O que não parece não estarmos de acordo, é que a grande maioria desses jovens não têm grandes hipóteses de brilhar no "mundo dos grandes" e muito dificilmente "no seu mundo" sem ajudas externas. Não por culpa deles claro. Mas sim pk infelizmente há inergumenos que dão substâncias proibidas em idades precoces aos atletas. Sou professor de educação física, mestre em ciências do desporto pela fcdef, e com muita pena minha falo deste assunto. Tenho imensos alunos meus atletas de alta competição, 3 deles no ciclismo de estrada e fico pasmado, para não dizer chocado com os ciclos que eles fazem e com as substancias que os treinadores dos mesmos os obrigam a tomar, em favor "dos elevados interesses pessoais e do clube". Atletas alguns deles pertencentes á selecção nacional de natação, e um deles uma promessa do ciclismo.
A minha posição vai no sentido de fazer ver que esses grandes atletas, os puros, só ganharão se nessa prova não houver kitados, caso contrário, por norma, não ganham.
Agora, a posição do amigo Paulo, eu percebo-a e respeito-a, como respeitarei todas as outras. Não se pode é perder a compostura e a educação. Para isso somos adultos e no meu caso pai de família.
Continuemos a motivar os jovens para a pratica desportiva, para a pratica saudável, não aquela k muitos pais desejam (pk há pais k são uns frustrados, colocando no filho a pressão de ganhar aquilo que ele próprio não conseguiu). Muitas vezes são esses pais que os motivam a tomar algumas substancias (cafeína, proteína, vitaminas, aminoacidos, diureticos e outras k não vale a pena dizer pra não chocar o sr Paulo. Repito amigos, desporto não é saúde, que o digam os ex desportistas todos rotos e cheios de mazelas.
Doping? Houve, há, e sempre haverá...................esperemos é que haja pais bons, que não se deixem levar pelo entusiasmo de ter filhos campeões.......do seu bairro.
Contrariem , critiquem, desfaçam o meu ponto de vista, mas com educação…………
boas pedaladas.................
paulo marinheiro
Utilizador Banido
Depois de perceber as responsabilidades acrescidas pela profissão do caro colega, que está directamente ligado ao desporto jovem e à formação de cidadãos, mais chocado fico com afirmações que são "bebidas" por "crianças", que aqui vêem e se por um lado uns podem entusiamar-se pensando que o mundo do desporto é realmente doping... outros podem desmotivar, e até desvalorizar quem ganha.
Há uma visão distorcida quando fala em suplementos como se fosse doping. Cafeína, proteína, vitaminas, aminoáciodos, não são doping... senão não podiamos comer nada, pois "tudo" o que ingerimos tem estes elementos atrás, e não é errado nem está em discussão a suplementação, que cada um deve e pode "legalmente" tomar nas doses que achar melhor depois de bem informado sobre consequencias de excessos. Numca ví nimguém acusar positivo a Vitamina C...
A história do pai bandido e que pressiona os meninos para ganharem o que ele não ganhou é velhinha... eu digo-lhe: pai bandido é o que vai para o café torrar a guita em aguardente e despeja o puto numa qualquer equipa que "o eduque e forme" por ele. Sempre só haverá atleta quando na sua juventude teve pai "bem" presente, entusiasmado e colaborante, de uma forma ou de outra, e nisso podia dar-lhe "n" exemplos que ocupavam a página toda: Vanessa Fernandes, Armstrong (mãe), Louis Hamilton (pai com 3 empregos para pagar corridas do filho), Julien Absalon (quem não viu aquela mão apontada ao céu nas olimpiadas... a dedicar ao pai falecido que foi unha e carne com ele nas corridas e tudo que teve a ver com elas, a de ouro), e tantos outros. Podia dar-lhe exemplos de atletas com grande potencial que conheço, mas que o pai não o leva lá... nem sequer lhe dá condições estando-se nas tintas, mas aí falava de pessoas que conheço, pela negativa... O miudo sózinho não faz nada, pois é novo... o que vemos é muitos miudos que aos 30 anos querem, agora já por sí, com independencia financeira, tentar ser o que não foram... tarde demais! Eu gostava muito que o meu pai tivesse apoiado aquilo em que eu sentia que era mesmo bom... não apoiou... e um Kart era meia fortuna, quanto mais as deslocações... sou um piloto de F1 frustrado (no sentido soft e como exemplo, claro). Conheço um grande atleta elite deste país betetistico que diz directamente que foi o que o pai quis que ele fosse, e com isso perdeu uma talvez super carreira desportiva, não tendo tido um décimo do apoio que têem os meus putos (dito por ele). E além disso e no aspecto meramente pessoal, diga-me: existe algo mais bonito e que realize mais alguém, que ter, por meio do desporto, um amigalhaço do peito no filho de 16 anos, quando a maioria anda à nora, sem saber o que o puto faz???? e onde e com quem anda???? e nem consegue falar com ele, pensando que hi5 é uma coca-cola nova????
O campeão olimpico de qualquer modalidade, primeiro teve que ser campeão do seu bairro! E foi-o com orgulho concerteza e deverá ter a taça ainda nas top ten... cá em casa está junto à de campeão nacional e vencedor da taça de portugal, juntamente com as das vitórias na taça de espanha.
Quanto ao doping que o Sr. diz que os atletas da estrada e natação seus alunos tomam, não é de crer que lho contem a sí concerteza, que essas coisas não se contam assim ao professar, tipo : prof. hoje dei duas na EPO... sejamos realistas e não é por termos na aula um campeão que podemos vir cá para fora dizer o que imaginamos que ele toma, pois só de imaginação, que NIMGUÉM o diz na aula, e nimguém acredita que o campeão mesmo que o fizesse, o disse-se em publico... isto não tem cabimento.
Para finalizar, penso sinceramente que não ofendi nimguém, nem fui malcriado com ninguém, mas efectivamente Prasquete,... há nesta sociedade o direito de não respeitar uma opinião e ser absolutamente contra, com respeito, claro... e neste caso explico o porquê da talvez mais "forte" opinião dada por mim sobre este infeliz post: há coisas que, por poder influenciar de forma vincada, a forma de ver e entender o mundo, não podem ser ditas publicamente de animo leve. Há responsabilidade de todos neste assunto, e a ideia é fazer perceber aos novos (sim, aos novos só, que são o futuro de algo diferente para melhor, pelo menos na mentalidade) que é possível perfeitamente, sêr para quem quiser sê-lo, campeão do bairro, do país, da europa e do mundo... sem tomar drogas (e suplementos não são drogas). A ideia não pode ser, fazer ver aos novos que "...ou és dopado, ou não ganhas, e quem ganha é dopado..." e principalmente, não pode vir essa ideia de quem é pago e tem responsabilidade de educar e formar para fazer melhores cidadãos (espero que o Sr. não se ofenda com esta opinião clara sobre as suas responsabilidades na sociedade).
À rapaziada nova, repito e acreditem: é perfeitamente possível ganhar sem NADA!!! Dar-vos-ia vários exemplos de campeões nacionais de ciclismo, quer de estrada, quer de Btt-Xco, nas camadas jovens, se pudesse colocar aqui nomes... Apertem convosco nos treinos ,no descanso e na alimentação, com os vossos treinadores para se aplicarem e trabalharem séria, entusiasmada e progressivamente e com consciencia, e com... os vossos pais para vos ajudarem, seja a levar-vos lá, seja a comprar-vos pelo menos uma corrente nova, para não deixarem de ser campeões por causa de 20€!
paulo marinheiro
...que não vai de férias às caraíbas ou ao brasil... gasta os créditos a enervar-se numa qualquer pista na suiça, ou na itália, ou na china se tiver nível... não para ganhar o que numca ganhou, mas para numca os meus filhos acordarem e dizerem: "...o que eu podia ter sido, se o velho me tem apoiado...". E oiço tantas vezes isto na rapaziada que tinha grandes capacidades natas, e que não teve as condições que os meus putos têem... E se um dia a rapaziada acordar e disser: já chega, não quero mais... valeu sempre a pena, e nada retirará o que vivemos em conjunto de bom e mau (sim!... mau! desporto de alta competição tem muitos momentos muito maus...), que ficará marcado na nossa história... que contaremos aos netos (que iremos também ajudar a ser campeões do bairro primeiro, e mundiais depois, nem que seja de carrinho de esferas ou guelas...).. em conjunto, do tipo: EU ESTIVE LÁ...!!! Muita gente não poderá contar isto mais tarde... porque não é pai bandido, dos tais que apoiam os filhos!!!
